PCMCIA interface
Hello, i have a vector-tech CAN card that is configured to run a program called CANalyzer. I am trying to connect to a radio module, and be able to control this radio module using the CAN card on labView.
How can i accomplish this? thanks!
(3,046 Views)
Hey Bunmi,
Thank you for contacting National Instruments!  Vector has a CAN driver for Labview.  Dowloading this driver is going to be the best way to communicate with a Vector CAN card in Labview.  This knowledge base [broken link removed; article no longer available] contains a link to where the driver can be downloaded.
I hope this helps,
Jason W.
Application Engineer
(3,018 Views)
thank you Jason.
(3,014 Views)
