PDA Acquire Multichannel Waveform VI crashes PDA
When I try to use "PDA Acquire Multichannel Waveform" VI the PDA freezes (needing a reboot). I'm using a DAQCard-AI-16XE-50 in a iPAQ h5550 with single slot backpack. The Single Channel Acquire VI works fine. I'm using a block diagram supplied by NI. This VI is very new so there is very little information on it as yet, has anyone got it to work? How? Thanks
(3,156 Views)
Tim,
Below, I have attached a modified version of Cap Acq Size.vi from labview\vi.lib\pda\easy-nirlplib.llb. Go ahead and replace your version of the VI with this one. This should allow your DAQCard-AI-16XE-50 to function correctly.
Let me know.
Spencer S.
(3,156 Views)
