PDA Bluetooth DLLs
The instructions for installing the Bluetooth DLLs for use on PDAs states:
'Do not install the WIDCOMM Bluetooth DLLs if you are using the Microsoft Bluetooth driver'
Does anybody know what happens if you do install the DLLs on a Microsoft device?
Thanks in advance
ssk
(3,253 Views)
Hi ssk,
If you were to use the WIDCOMM Bluetooth DLLs with the Microsoft Bluetooth driver you would see errors when you called Bluetooth VIs and functions due to the conflicting pieces of software.
For some more information on this please read this thread from our forums.
Tom
National Instruments UK & Ireland
(3,227 Views)
