PDA Discussions
I'm interessted in LabVIEW PDA programming because:
I like LabVIEW programming and I wan't to use PDA's for consumer test datalogging.
First of all, how about a PDA Topic or a PDA category?
Topics I would like to discuss are:
-Experiences about applications robustness (PDA,OS, UI)
-RS232 capacity
Starting with some questions:
Howto run always (and only?) one PDA application?
Are there systems (OS) supporting something like watchdog functionality?
Is it possible to store the data 'directly' to the memory stick / Compact Flash ? (Hotplug?)
Greetings from Germany
Henrik
Henrik
LV since v3.1
(4,428 Views)
Here [broken link removed; article no longer available] is some information about the Serial (RS232) functionality of the LabVIEW PDA module. There are also links at the bottom of that page to take you to more information about it. This should hopefully clear up some of your questions.
J.R. Allen
(4,428 Views)
