PDA Module File path
How to get the current directory path (where the executable runs)?
Message 1 of 8
(6,083 Views)
Use the function "Current Vi's Path" and strip it twice using the stip path function. This is also the case when using a dll.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
Message 2 of 8
(6,082 Views)
Thanks, but "Current VI's Path" VI is not available on the PDA module.
Joe
Message 3 of 8
(6,082 Views)
Joe,
On the Pocket PC, the executables are downloaded to the Program directory, which is just \Windows\Start Menu\Programs. If you are doing File I/O from the PPC, you just reference the file path in the same way. For example, you could write to "\My Documents". There is no drive included in the file path (no C: or anything).
The Palm may be different -- I would check with the manual or their tech support to find out how to reference file paths.
I hope this helps!
Liz F
Message 4 of 8
(6,082 Views)
Thank you.
Joe
Message 5 of 8
(6,082 Views)
I am also have problem with path in PDA module.
When I using path constant and try to enter path (for example \Windows\Data\sin80.dat) LV create path D:\Windows\Data\sin80.dat, and I can't delete "D:\".
Can You explain me error.
Message 6 of 8
(5,983 Views)
Message 7 of 8
(4,323 Views)
how can i create the file path with browse option in pda?
thanks in advance
Message 8 of 8
(3,971 Views)
