PDA Refresh LV 2009
After compiling my application from 8.5.1 to 2009, I notice that the application suffers from 'blinking' presumably when the screen refreshes. Has anyone else witnessed this?
I have attached two videos, video02.avi is the 2009 version.
Thanks in advance
Message 1 of 10
(4,858 Views)
Is the only change literally to open your 8.5.1 project in 2009 and deploy to the pda?
Message 2 of 10
(4,830 Views)
Hi Mark,
Yes, that is the only change.
Simon
Message 3 of 10
(4,827 Views)
I have a PDA here, I'd like to try your app on my PDA to see if I can reproduce it. Could you attach your code?
Message 4 of 10
(4,824 Views)
Do you want the executable or LV Code and what version do you want it in?
Simon
Message 5 of 10
(4,822 Views)
LabVIEW code, and the old version (before saving it in LabVIEW 2009)
Message 6 of 10
(4,817 Views)
Hi Mark,
Apologies for the delay in replying.
I have had to do a special build of the software as it relies on one of our products being present.
I have also discovered another bug that is causing the Label.Text property of a Boolean control to be hidden (was visible in 8.5.1).
The code and executables will be quite big, what is the best way to get them to you?
Message 7 of 10
(4,752 Views)
Please upload to ftp://ftp.ni.com/incoming/ in a zip file named 'PDA_Refresh_Issue'
Message 8 of 10
(4,721 Views)
Done, please refer to readme.txt within the zip file.
Message 9 of 10
(4,715 Views)
I have taken a look at this and I was able to reproduce the issue on my Dell Axim x51v.
Have you tried deleting the problematic controls and recreating them in LVPDA2009?
Message 10 of 10
(4,640 Views)
