PDA and 6024E card give Error -200428
Since installing PDA for Labview 7.1 every time I run an example program on my HP 5550 I get the error -200428. I have loaded the Pocket PC drivers and also tried to write my own program using the Daqmxbase vi's. Any help would be much appreciated.
(2,510 Views)
Mark,
Greetings! This error generally means that the task name that you are trying to use is not properly defined. Ensure that you have the task defined properly by using the DAQmx Base Task Configuration Utility.
Did this program work before you installed PDA for LabVIEW 7.1?
AnujD.
(2,510 Views)
