PDA and files are known
Hi there..
I have a zip files of the PDA
*.dll or something in the zip folder.
it is written in C language.
I need to communicate with the PDA and labview using a USB cable.
is it possible? how would i go about trying to do so?
where can i read more information on this stuff?
Krispiekream
(2,825 Views)
Accepted by topic author krispiekream
I am not sure if I got this right but if you have a DLL that communicates with the device, then you can just use the Call Library Function Node to make it work through LabVIEW.
Otherwise, if your PDA OS is Pocket PC 2003, Windows Mobile 5.0 or Windows Mobile 6.0, then you can use the LabVIEW Mobile Module to build and run LabVIEW applications on your PDA. This will be much easier 🙂
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,805 Views)
