PDA connection via wireless
good morning,
Im trying to connect my pc (host) and PDA (client) .when i use USB connection to receive network shared variable i have no problem to receive the data.
im not sure is it possible to connect both via wireless connection. what are the configuration that need to be done if its possible?
do i need to add on any special function if connection need to be done via wireless
thank for the concern
regards,
shamaran
(3,020 Views)
You won't need any extra configuration to be done. Just be sure to connect both to the same wireless network. I would suggest that you try this on a wired ethernet connection and then move on to wireless.
Message Edited by Adnan Z on 05-29-2009 06:54 AM
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,998 Views)
hai adnan z,
Thanks for the kind reply. I have tried the wireless connection and found the problem is not due to the configuration. the real problem is my FIREWALL is turned on. When is disable it the communication works. thanks
regards,
SHAMARAN
(2,976 Views)
