PDA example: Reading a jpeg file into a picture control
Hi
Does anybody have a simple PDA example of how to read a .jpg file and show it in a picture control. The jpg examples I've found does not compile for PDA.
(3,437 Views)
In LabVIEW for windows there are VIs to read in JPEGs, however the PDA module does not support those VIs, so I do not believe there is a way to display JPEGs.
(3,437 Views)
Evan wrote in message news:<50650000000500000045330100-1066448259000@exchange.ni.com>...
> to display JPEGs.
The hard way would be to write your own JPEG -> Bitmap / Array
de-compression routine. You will probably find example (C++) code at
the JPEG web site.
http://www.jpeg.org/jpeg_about.html
(3,437 Views)
