PDA pocket pc not supporting unbundle function
Hi ,
In the pocket pc pda module i get the following error App failed.Error code 130892003.Unable to lock memory chunk.
I found out that this error is generated during unbundling process.It was mentioned in the LV help that " PDA VIs do not support unbundling elements from nested clusters using a single Unbundle By Name function".
Even after doing all that i get the same error.I have attached the code which generated the error.If any of you know about this please let me know.
Geetha
(3,418 Views)
Hi Geetha
Have a look at this thread (Reply No. 7):
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,413 Views)
Hi Thomas,
Thanks for your reply. I really got good idea about handling clusters in PDA.
I have one more question ,"Can Pocket PC handle parallel loops".I tested a small vi with two parallel while loops and i found that the only one loop was executed.
If you know about this please let me know.
Geetha
(3,404 Views)
A LabVIEW application on the PocketPC can definitely have more than one loop. Make sure it runs properly on the computer and that you don't have dependencies between the loops.
I have had recently a windows CE (not PocketPC) PDA where for some reason my applications would only run at a normal speed if I kept tapping the screen. I haven't had any chance to check it, since I had to return it, but that was a single loop anyway, so it shouldn't apply to your case.
___________________
Try to take over the world!
(3,400 Views)
