PDA tab control refresh?
I am using a tab control on a PDA app (Pocket PC 2003, LV 7.1). If I resize or replot to a graph on an inactive tab, the graph is pulled to the front regardless of what tab is selected. The graph will cover text and some of the controls/indicators in the currently active tab.
I tried using the show/hide control VIs, but it happens even with the graph indicator set to hidden.
Anyone else experiencing this? Workarounds?
Ryan
(3,907 Views)
Ryan,
I tried to reproduce your issue and wasn't able to. I've attached the simple VI I made to test it. Do you have a simple example illustrating the behavior?
JR A.
(3,907 Views)
I built a similar VI and came to the same conclusion. The attached VI demonstrates the issue I reported in my initial post. It is related to the Configue PDA XY Scales VI.
Thanks for your help.
Ryan
(3,907 Views)
Update:
I tried a couple more things yesterday and found a decent work around. I created a flat sequence that includes 2 frames, one hiding the tab control, one showing the tab control, and wired my last graphing operation to the flat sequence as an input. This has the effect of refreshing the tab control.
Ryan
(3,907 Views)
