PDA tab control 'tabs' remain visible even if set to invisible.
I have set the 'tabs' on a tab control so they are not to be visible. The tabs do not appear on the front panel of the LabView program window but when I "Build for PDA" and run the it on the Pocket PC (IPAQ HP2210) the tabs are still visible.
LabView 7.1 with PDA 7.1 module.
(2,514 Views)
Hello –
I have been able to reproduce the behavior you are describing. I have submitted a report to our R&D group so that they can investigate the problem.
Thank you for your feedback. If there is any additional information from R&D I will post it here.
SVences
(2,504 Views)
