PDA with Elvis
 Is it possible to make the PDA VI to control the input or output of the circuit on NI ELVIS????
(3,299 Views)
Hi Nsour,
Unfortunately, it is not possible to make a PDA VI able to control the input and/or output of the circuit on NI Elvis. If you take a look at the NI Elvis software page, it shows that NI-ELVIS 3.0.2 installs NI-DAQmx 8.7.1 by default. It does not run on NI-DAQmx Base driver, which is what the PDA module uses. I hope this helps answer your question!
Carla
(3,245 Views)
Dear Carla
Thank you
(3,231 Views)
