PDF generator for LabVIEW 2015
I am migrating current source code in LabVIEW 2013 to LabVIEW 2015 with Windows10 operating system. An issue is the latest library of PDF Toolkit 1.1 support up to LabVIEW 2013. Any suggestion of PDF creating toolkit which supports LabVIEW 2015?
Thank you very much,
Jeanne
(4,911 Views)
Seems like this is an issue dating back to LV 2014 as well since the installer can only run in 2013.
This is the product page from the third party supplier in the Netherlands. I would suggest contacting them to see what's going on with the toolkit.
This is one of the sucky things about third party add-ons, NI has say in keeping them up-to-date.
I haven't tried this, but maybe an ActiveX link to a PDF creator of some sort will work for you. Check out this link.
You could also save a report as a PDF if you are using the Report Gen Toolkit.
Cheers
(4,900 Views)
Thank you James, very helpful. I'll see if ActiveX works.
(4,894 Views)
