PDF report generation
Hi there I am using labview 14.0 to generates report in excel, now instead i want to generate pdf directly
how can i do that?
(4,207 Views)
I will guess that you're using the Report Generation Toolkit. In this case just save your report with the .pdf extension.
Ben64
(4,166 Views)
As already mentioned, I think you are using Report Generation Toolkit. Link below provides you information to Save word or excel file in a .pdf format
https://forums.ni.com/t5/Example-Programs/Save-Word-or-Excel-report-as-a-PDF-using-Report-Generation...
Hope it helps
Rahul
Express your Thank you by giving Kudos and Mark as solution
(4,140 Views)
We use "CutePDF" it installs as a printer, so making a PDF is as simple as printing a document.
=== Engineer Ambiguously ===
(4,125 Views)
