PDa delete function
I am currently having trouble with a application I am trying to run on a TPC-2106 screen using the PDA module. I am attempting to delete all files following a certain naming convention, I have managed to produce the file names as strings however I have been unable to get the delete file function to accept \harddisk\ as a valid path (I am under the impression this is due to the function assuming it is a relative path). Can anyone suggest a work around or provide any insights to the nature of the problem?
(3,112 Views)
you said ".... I am trying to run on a TPC-2106 screen using the PDA module..."
But for the TPC you will need the LabVIEW Touchpanel Module, not the PDA Module!
Christian
(3,090 Views)
