PEER to Peer streaming between DAQ and FPGA
I want to acquire data from 6 PXIe 6368/6378 DAQ Cards and Send it to NI PXIE 7976R fpga for processing and and then display that data on host PC.
i have used DMA FIFOs but its taking around 1 sec can i use PEER to Peer  streaming in this case.
Acquire data from DAQ cards and send it to FPGA via P2p fifo.
Message 1 of 10
(1,528 Views)
That sounds like a great use case for P2P.  Unfortunately DAQ cards are do not support P2P.  See https://www.ni.com/en/support/documentation/supplemental/10/an-introduction-to-peer-to-peer-streamin... for a list of open FPGA hardware and other instruments which support P2P.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 2 of 10
(1,487 Views)
As Terry cited, only open  FPGA hardware cards like FlexRIO or RF instruments support peer to peer streaming and DAQ is not part of it. Your only option is to replace your DAQs with FlexRIO + ADC combination, then do onboard FPGA processing or stream to another FPGA for processing.
What is your application? how does it benefit from streaming?
6368/78 are mixed signal cards, are you performing stimulus response test?
Santhosh
Soliton Technologies
Message 3 of 10
(1,479 Views)
I have Four 6368 DAQ cards and 2 6378 cards.I am acquiring real time data from 96 channels.After acquiring data on host is there any possibility to send data to FPGA via P2P FIFO ..If its not possible what is fastest method possible in this scenario for data transfer?
Thanks.
Message 4 of 10
(1,466 Views)
Thanks.
You can implement logic on the host to combine data from all channels and send it to FPGA for processing over Host - DMA FIFO for FPGA but not "streaming".
https://www.ni.com/docs/en-US/bundle/labview-fpga-module/page/transferring-data-between-the-fpga-and...
Santhosh
Message 5 of 10
(1,453 Views)
Thanks.
What kind of processing are you looking to do on the FPGA?  What will you do afterwards?
If the data is sent to the Host, you could process it on the CPU or a GPU.  In other words, once you have sent stuff to the Host, the latency benefits of an FPGA are lost so might as well save on development time and do the processing in software.
I do not know the big picture so this may not be the best thing to do.
ALE Consultants
Message 6 of 10
(1,438 Views)
I want to do DDC and then decimate and filter out the data.Data size being huge CPU takes high time time thats why i am using 7976R.GPU option is not available.
Message 7 of 10
(1,402 Views)
That is what i am already doing..but searching for better alternative for improving time ..
Message 8 of 10
(1,401 Views)
Yeah, in the past, I had used a 7822R card as a DSP to implement the decimation filter for a PDM data stream (35 in parallel) and the host was explicitly transferring data between the data acquisition part and the DSP implementation on 7822R.
Santhosh
Message 9 of 10
(1,366 Views)
I concur on this.  It may be good to swap out the DAQ cards for R Series cards or something which has an open FPGA and/or supports P2P.
ALE Consultants
Message 10 of 10
(1,333 Views)
