PFI Pin Trigger for a Solenoid Valve
I am currently trying to trigger a solenoid valve based on an analog input (level=5 and slope=falling). I need to do this as fast as possible (5 micro-s delay at most). I talked to some people at NI and they recommended using a reference trigger and routing the signal to a PFI pin. I attempted this but it is triggering on the rising edge even though I clearly stated falling edge in the code of the program. I am confused. The code seems like it should work, however it does not. I would appreciate any help.
M^2
(3,240 Views)
Make sure that the analog signal and ground are hooked up right otherwise you ntrigger will also reverse, that is the rising edge will look like a falling edge on the differential input.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,220 Views)
 Hi M^2,
 The DAQmx Export Signal.vi you have in there is routing a Reference Trigger event to the PFI9 line. I'm not sure this is what you are wanting to do.
Your application sounds like the following:
  1. Acquire a analog input when a trigger condition is met. This trigger condition is a falling edge of the analog input signal.
The VI you attached should work, I made a slight change to the source of the trigger condition and removed the DAQmx Export Signal. The analog signal to be monitored should be wired to pin 20, the source is "/Dev1/APFI0". Where Dev1 is whatever name your daq card is known by to MAX.
 I hope this helps! Please consider the suggestion made by falkpl as well, that would definetly cause the trigger slope to be exactly reversed.
MatthewW
(3,200 Views)
What kind of solenoid valve are you using which can respond in microseconds? All the valves I have seen require tens of milliseconds or more to operate.
Lynn
(3,183 Views)
Right now I am recording an analog signal. The valve will turn on as soon as the program runs (5V). However, when the analog signal is at level=5 and slope=falling edge I want to turn the valve off. I am aware the valve will take time to shut off but I would like the trigger itself to be as precise as possible. As in when the slope turns falling edge while the level is 5 the trigger will occur and send a signal out in at most a 5 micro-second delay.
(3,172 Views)
