PFI used as a Digital Input PXI 6355
I have something  I cant seem to find the answer to and its probably simple to someone.
I have a PXI system with a 6355 card. I need to use 4 of the PFI lines as digital inputs on port 2. I get an error when I try to start the task using port 1 or port 2. Port 0 works fine. Port 0 , Port 1 and Port 2 work fine in MAX. Something simple I am missing for sure. Thanks in advance for an help!
(478 Views)
Accepted by topic author JCIV
PXI-6355 only supports sample clock timing on Port 0. You can only use On Demand timing on the remaining ports.
Reference: NI 6355 Specifications
https://tmesystems.net/
(451 Views)
