PID制御の並列制御
一つのFlat Sequence Structure内で二つのPID制御を並列に行うことは可能でしょうか?
(228 Views)
Accepted by topic author テュポーン
Hi new member from Japan,
@テュポーン wrote:
Is it possible to run two PID controls in parallel within one Flat Sequence Structure?
Sure.
But why do you want to use a sequence structure at all?
And why do you need to write your text in extra large?
(218 Views)
返信ありがとうございます。
実行するプログラムの順番を決めたかったのでシーケンス構造を使いました。また特大でテキストを書いたのはミスです。
(207 Views)
@テュポーン wrote:
Thank you for your reply.
I used the sequence structure because I wanted to determine the order in which the programs would be executed. Also, it was a mistake to write the text in oversized font.
To enforce execution order you should learn about DATAFLOW. All you need are wires, no sequence frames!
And I consider it also a mistake to write Japanese in the worldwide English board. There's a dedicated Japanese regional board!
(197 Views)
