Is there a bug in: "PID Advanced Integral Action (DBL).vi"? If "Initialize" is true there is a "select" conected to the variable "Initialize" in the case structure, that does not make sence to me. Kindest regards, Stefan Pofahl
No, probably there is no bug! Forget my question! The case criterias are filtered through an "Or" operator. So even if "initialize" is false, the criteria for the case structure can be true. Kindest regards, Stefan Pofahl
