PID Control to turn Heater On/Off
I am using a cDAQ chassis to control a temperature loop, where I read the temperature using a thermocouple and turn the heater on/off using a relay connected to a digital output card (NI 9477, does not support PWM). I am using the PID.vi to create a PID controller. But this vi provides the output as an analog value in the range of 0 to 100 and I need to convert this value to a PWM signal. Is there a sample program available that shows how to convert an analog value to a PWM signal. I did find a sample program on the ni website (pid_control_pwm.lib) but the version is 5.1 and does not work with LabVIEW 8.6.
This PID loop is a part of a large program. Does the PID need to be in an independant timed loop? How should I adjust the loop period such that it does not get affected by other things in the  program?
Also can someone explain how the Autotunning vi works. I tried using the VI but it never completed the autotunning. It goes to the last step of the wizard and then never comes out of the loop.
Thanks.
(6,277 Views)
For your PWM signal: think of an array with 100 Elements. For 100% all are 1, for 50% half of them. How do you distribute these 50 ones? How long should a 1 or 0 be?  That is up to you!
Well, some points to consider: AC or DC heater?
Really a mechanical relay?
Power and Power Line Flicker (a fluctuation in the voltage of AC power lines, whose compliance is regulated by IEC61000-3-3, Wikipedia)
However a good approach is to have 10 power steps, create the arrays , feed them into one DO .
If It is a slow process (you mentioned relays) software timing might be fine.
BUT think about software failures and ADD A INDEPENDENT OVERTEMP GUARD
For heater there is a alternative to PID (the I part here is the candidate for overshoots and oscillation) , search for TBH (Take back half) algorithm.
Message Edited by Henrik Volkers on 04-30-2009 10:32 AM
Greetings from Germany
Henrik
LV since v3.1
(6,236 Views)
Hi Controls_Engineer,
It is doing the Ziegler-Nichols closed loop tuning, edging up Kp, then Ki, then Kd.
Do you have a model for your system? If not, you could attempt to create one using the System Identification tools and start from there.
Jeff | LabVIEW Software Engineer
(6,174 Views)
