PID Controller: Process Variable not changing
Howdy,
I am currently working on a project where I am controlling a two way acting pneumatic piston with two electronic pressure regulators. These pressure regulators accept a voltage range of 0-10 VDC. I am wanting the pressure regulators to be controlled with the speed of the piston measured by taking the derivative of the data obtained from an LVDT. I am very new to LabView and I am having a lot of trouble with this. I am using a PID controller and my process variable, the derivative of the LVDT data, is not changing at all whenever I change my setpoint variable. I have attached my VI below. Am I missing something or are my PID gain values just not right?
Thank you for any help,
Shafique
Texas A&M University
(2,763 Views)
Oops, the attachment never made it.  🙂
Bill
CLD
(Mid-Level minion.)
(2,757 Views)
Hm, weird. I'll try and attach it again. Hopefully it works this time.
(2,751 Views)
Hi Shafique,
This can be seen by your use of ExpressVIs and DDT wires all over the place…
  • Your DAQAssistent is set to read 250 samples per channel, but you use those PtByPt-Mean functions on each channel/DDT wire: which result do you expect here and which result do you get? (I guess that will be two different values…)
  • Why do you need a MergeSignal ExpressVI to create a 2D array from 5 scalar values ("Trash"), just to pick the first row from this 2D array???
  • Why do you hide two PID functions inside that case structure, both using the very same PID gains? Why don't you switch the output channel afterwards? Do you know each PID function maintains their own internal state???
  • Do you REALLY need floating point values formatted with 20 decimal digits???
  • Why don't you cleanup your code? Messy code is hard(er) to understand…
  • How did you determine the PID gains?
(2,711 Views)
Hi GerdW,
I did not realize I was making so many mistakes within my code. That being said, do you have any recommendations on how I should clean up my code?
Thank you,
Shafique
(2,647 Views)
