PID (FPGA) - Convert 16bit output to 24 bit
Im controlling a device in Closed Loop using the PID (FPGA) vi.  The output of this is I16, but it would be nice if I could convert it to a I24, or I32.  The output of this vi is sent to two different Analog Outs on my Op-Amp circuitry.  The op-amps are set up as summing amps, so it would be ideal to send the lower 8 bits to the first AO (fine output), and the top 16 (15+sign) to the second AO (coarse output).
I haven't found an easy way to do this yet.  So far, I've been thinking of just using the I16 output value, split it into two 8 bit numbers.  The lower 8 bit controls my first AO.  The upper 8 bits is combined with another 8 bit register that gets incremented everytime the 8-bit number becomes saturated, and controls the 2nd AO.
I've attached a pic to make it more clear (I hope?).  If I should be doing this another way, please let me know.
Or maybe I need to be controlling this system with 2 parrallel PIDs? One controlling the coarse control, the other the fine.  The feedback would be the same for both PIDs.  16 - 24 bit PID output.JPG
(3,657 Views)
Actually, nevermind for now.  Im just going to manually control the upper 8 bits of the coarse control.  This way, there will be no 'jumps' when incrementing the upper 8 bits.
Thanks!
(3,645 Views)
Hi bones,
even on FPGA you should be able to use "split numbers" and "join numbers" functions...
And you can use boolean operators on numbers. Like sign = I16 && 0x8000 Smiley Wink
That way you would get away from all those number TO boolean array TO cluster of booleans TO unbundle TO bundle TO boolean array TO number conversions (also called RubeGoldberg, search for this in the forum!).
Message Edited by GerdW on 12-07-2009 08:52 PM
(3,639 Views)
