PID PWM, getting of 0-15% part of range
Hi guys,
             i have just changed the heater control from thermostatic to PID in an aplication, i am using a PID.vi and a SQ wave gen.vi
So i use the PWM output as the duty cycle for the sq wave. But i dont want the range to be 0-100% , i want to skip the first 15 or 20% to avoid relay chatter however i want it to be 0 when its off (so i can't just set the range limit to 15-100%)
Is there any built in way of having this jump in range limit ? (i could just set the range to 15-100% then stick the whole thing in a case structure and disable it all for 0)
Thanks, Zac
(2,710 Views)
Hello Zac,
A simple Select function or Case structure seems a perfectly viable solution!
23524iC16804CA726F17D9
All the best with the rest of your application!
Kind Regards,
Michael S.
NI UK & Ireland
(2,678 Views)
