PID Stop
Hey everyone,
I’ve got a pretty straightforward setup here, with supply and return pressures being monitored and controlled. We’re using a bang-bang solenoid valve system to supply pressure. What I want to do is stop the PID indefinitely once the return pressure matches the supply, but still keep monitoring pressure. Any tips on how to do this the right way?
Also, I’m having issues with my file’s memory usage continuing to grow. Any advice on managing this would be awesome too. Vi attached. Thanks!
(700 Views)
If you can back-save your VI to an earlier version (I recommend 2019) then a lot more people can read it.  Many (most?) of us do not use the most recent version.
(662 Views)
