PID Temperature Controller working with an ON/OFF time cycle
I trying to reproduce into LabView a PID temperature controller that you buy from omega for intance.
I want to use the PID build in VI. The PID output from 0-100% will be multiply by a time cycle value (e.g. 5 sec). If the output of the PID is 50% and the time cycle is 5 sec, that means that my heater will be ON for 2.5 sec. Heater ON means that I'm sending a DO signal to a relay, which turn on the heater.
I don't know how to program this. Anyone could help?
(5,050 Views)
Dear Viga,
What hardware are you working with?  (input and output)
Do you have the PID toolkit for LabVIEW?
To do PID control with a digital output (on/off), you will want to do PWM (pulse width modulation), which is what I believe is what you are describing in your post.
There are multiple LabVIEW shipping examples that show you how to do PWM, depending on which hardware you have. I would check out one of these examples appropriate to your hardware, and add PID control to it, based on your input.
If you have a multi-function DAQ card, then I recommend looking at the PWM-Counter Output example VI, which actually implements proportional control. You would just have to replace the proportional control subVI with a PID VI and make a couple other small changes to adapt the example to your application.
Hope this helps,
~Nate
(5,012 Views)
