PID and fuzzy logic toolkit
He
I'm trying to create a motor position control using the PID toolkit. Is there a step response feature or another function that shows the response of the PID system, percent overshoot, settling time, etc? If not, is there a way I can create a step response using this toolkit?
thanks,
kirby
(2,647 Views)
What is your setup so far?
If you are using the LabVIEW PID function and are controlling a plant, you could just change your setpoint and monitor the process variable on a LabVIEW chart.
If you are simulating it all, then there are step reponse functions that you can drop into your simulation loop like done here.
Lewis Gear CLA
LabVIEW UAV
(2,637 Views)
