PID application
Hi everyone,
First, I bed pardon because this message is not directly related to coding. I already made a LabVIEW code for PID controller and want to implement that for controlling pump flow rate. Does anyone here, who has work experience with LS inverter (SV 015iG5A-2), NI USB 6009 and 220V pump? I have some questions......
Thanks in advance.
(3,062 Views)
Hi Milon,
did you solve your questions?
Which problems do you have to connect the inverter to your USB6009?
(3,001 Views)
Hello Mr. GerdW,
I am replying after a long time. I have attached one PID control code here. I need to control pump flow rate based on sensor value through PID controller. I am using LS inverter for controlling pump and this is connected with the computer (LabVIEW) through RS232 to 485 converter cable. Problem is:
1. during running, it shows the "scan failed" error (picture attached_PID code error-1)
2. If I remove the "scan from string" option, then another error is showed (picture attached_PID code error-2)
any suggestion to overcome this problem?????
(2,884 Views)
