PID closed loop
My objective is to create a closed loop speed controller but like a guy said on one of his posts there all on the toolkit but I do not have the toolkit. I also can not afford the toolkit in my budget.
(3,703 Views)
Do you have a question?
(3,692 Views)
Hi duke,
maybe you team up with Gotti?
(3,670 Views)
You can easily code a PI or PID controller without the toolkit - when it is written in a form for sampled data (discrete time) then it is quite simple.
Search for "incremental PID controller" and I'm sure you'll find the simple equation to implement within a timed loop (assuming you are wanting to control something real / realtime, and the controller you want is PI/PID).
You might need to add some additional software functionality to keep it working well - e.g. limits, anti-windup, rate limits, filters - but depends upon your application.
Consultant Control Engineer
www-isc-ltd.com
(3,623 Views)
