PID control: actual system elements and simulation elements
Dear
I have  a dc motor with 12 volt operating and has a tacho meter for speed estimation with H-brighe for PWM [pusle width modulation]
its required to put pid controller to control speed
basically  I will simulate the system before any implementation
the problem is if I implement the transfer function (mathematical model )  of motor in labview
for ex.[from control theory ]
 w/v= 1/2s+1;
w: rad/s and v: is the applied voltage
so in simulation what is the input and output of this transfer function ?? Voltage,pulse width or anything?? if volatge what will its range
and what its output will represent ?? speed ??
I mean I am confuse about connected theory or simulation [input and output ] with physical system [input and output ]
best regards
hi ?Q>
(4,605 Views)
I don't know how the applied voltage would equal V in this case. It doesn't make sense to me. This article on PID control theory might help.
https://www.ni.com/en/shop/labview/pid-theory-explained.html
Rob S
(4,550 Views)
dear
to be clear in my thread
if i applied step signal on the transfer function of dc motor {speed/input} in software (labview) to get the step response
what will be the equivalent experiment in real world to get the same step response. ??
hi ?Q>
(4,540 Views)
It is still not clear what you are asking. I would expect speed to be an output of the system, and you would apply a step signal to the voltage to see how the speed responds, but you wrote "{speed/input}".
If you want the input of the transfer function to be a PWM duty cycle instead of a voltage, then the formula for the transfer function needs to include that conversion as well (from duty cycle to voltage). I can't tell you what that equation should be. If you only want to know what the shape of the response will be to a step input, without precisely modeling the time and amplitude, then it doesn't really matter what the input units are.
(4,516 Views)
@nathand wrote:
@mangood wrote:
if I applied step signal on the transfer function of dc motor {speed/input} in software (labview) to get the step response
Dear nathand
thank for replay
for
""It is still not clear what you are asking. I would expect speed to be an output of the system, and you would apply a step signal to the voltage to see how the speed responds, but you wrote "{speed/input}".
i think my ask is simple but I am bad in English so its hard to describe what I want
I will re ask again with simple description:
if I have a dc motor with its model [speed/input voltage=transfer function=1/s+1 ] and I apply a step response to such model in labview
I will get graph like this  which is the step response
So if I go to real motor what is the applied voltage or duty cycle to motor to get the same response above in figure ?? i mean is thier scaling !>.>??
For
"" then the formula for the transfer function needs to include that conversion as well (from duty cycle to voltage). I can't tell you what that equation should be"""
why you cannot tell me?? Is their problem in such that??Smiley Surprised
hi ?Q>
(4,507 Views)
mangood wrote:
For
I don't know what the transfer function should be. I don't know how you're generating the PWM signal, and I don't know if changing the duty cycle has a linear correlation with motor voltage, or some other relationship. Even if I had all that information, I couldn't give you the transfer function, because I'm not that good with the theoretical side of controls nor Laplace transforms.
Your graph shows a full system with a PID controller, but your equation describes only the transfer function of the motor. To duplicate the graph, you need a PID controller in addition to the motor, and it needs to be tuned to match the one used in simulation. Then you could make a step change in the setpoint, and the shape of the speed response would be similar to the graph. Of course there will be differences in scaling between the model and the real system - your graph has no units. If you have good measurements of your real motor, then you can include that information in your transfer function model so that the units will match.
(4,487 Views)
@nathand wrote:
mangood wrote:
For
Dear nathand
thank for your information
its clear now
the designed a controller for DC motor based on its mathematical model its hard
its need several parameters such tachometer and potentiometer sensors,PWM modulation
we may ask from NI control team to add tutorial on this problem related to DC NI motor
or any boday may guide us to such problem
best regards
hi ?Q>
(4,446 Views)
