PID control of heating element feedback
@nitad,
you are saying that I should not keep temperature gradient constant; means that, heat the sample and don't care the temperature gradient between two ends of the sample.
or you are saying that I don't need to go step by step stopping in some steps; means that, just heat the sample up to specific temperature which I need, measure gradient which can be grater that 5-10-15K.
best
Message 21 of 31
(2,935 Views)
@becidea wrote:
@nitad,
you need to apply power gradually to one end of the sample and measure continously the dV and dT, when the gradient reaches the value you want (5-10 K) stop heating and measure again while it decreases..
you can get one or few hunderth points that you plot as dV versus dT, and the slope of this is S
Message 22 of 31
(2,927 Views)
Hi Nitad,
one of your responses you wrote
2. make T1-x and T2+x where x is a function of time (from -3 to +3 for instance)
so I confisued how to do that, here for examples, x is a function of time, how to do that!!. There is also response time, near room temperature heater can reach desired temperature at x time but at high temperature stabilization will take much time!!..
bestt
Message 23 of 31
(2,918 Views)
I have the same error, but this solution didn't help me. I added screenshot to show te eror. additional thing can be send if it is needed.
best
Message 24 of 31
(2,884 Views)
hi
this thread is marked as solved so not many people are reading it. For your visa error :
you use the same address twice, you need to configure one after the another the Lakeshore parameters.
For the gradient :
Apply output power as function of time (for instance : Power*Sin(actual_time/total_time) ), the gradient will increase slowly you measure dT and dV.. but all this is explained in the papers I made several times suggestions you need to read
Message 25 of 31
(2,881 Views)
hi,
Thank you so much for your advices and I appriciate. Yes you are repeating:).. and the problem is not labview you said.Of course I need to know how to measure but the real problem is labview, even if I know something about measruement I need to do those thing via labview, so I don't know labview enough. Thats why I am asking any example which I can configure my vi. So you are advising me how to measure, but I don't know how to put this things to labview...
What you send as paper I have read, thank you again. I don't have any person to ask ar take help from near me. I have to do everthnig by myself...If you don't have advisor who can help you...
I hope I could explain myself...
Best..
Message 26 of 31
(2,857 Views)
hi
make a state machine and make small vi's everything doing an action
i can send you a vi doing a seebeck measurement but without understanding the actions you can not modify so you can make no progress
n
Message 27 of 31
(2,829 Views)
thank you for your thoughtfullness. Please send me your e-mail, I will send you my last vi with sub vi s. As you said I made many many sub vi so you can see easily I guess.
Thanks in advance.
Best again Best.
Message 28 of 31
(2,826 Views)
hi nathand, i wanted to open that png u uploaded, but i dont have PID.vi,
i think it is not sub.vi.
how can i install it?
Message 29 of 31
(2,794 Views)
kimse,
The PID.vi is part of a toolkit called PID and Fuzzy Logic Toolkit.  Please refer to the following link for more information on this toolkit.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209054
Drew
Drew T.
Camber Ridge, LLC.
Message 30 of 31
(2,765 Views)
