PID control of valves
Hello All,
I have three valves that are controlled by relays. When radioactive gas flows through two of them, it diffuses into saline water and I can measure the concentration of radioactivity in the water. The production of radioactive water is halted when I turn on the bypass valve. I would like to maintain a user set concentration of radioactivity in the water by regulating the valves. I made a elementary control vi without using PID control but the valves open and close too often. Can anyone point out how I acheive this using PID control or point me to references where I can learn something about PID control. Thank you.
(2,637 Views)
In Examples od Labview you can find some examples of PID, there are simple examples. I can brougth the PID control Toolset of LV. I implemented PID control with the Matlab script, implementing a algorithm,wich you can find easily in www
(2,637 Views)
