PID - control pressure
Hi All,
Does anyone  come across with PID controller that control pressure drop by controlling two signals.
Basically, controlling one  process value  (delta P) by controlling pump swash plate position and relief valve spool position.
Thank you in advance for any tips.
Gregorian7
(2,693 Views)
Typically the way I have seen this done was by breaking up the two control outputs into a "coarse" control and a "fine" control. The coarse adjustment sets the output to approximately what it needs to be and then the fine control tweaks the output to exactly what is needed.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,652 Views)
Hi Mike,
Thank you for your answer.
Is this feasibly to implement this solution in LabVIEW?
Have you seen any examples of such a control?
Many Thanks,
Gregorian7
(2,636 Views)
