PID control without NI-DAQ device
Using a proper programing architecture would help and a simple state machine lends itself perfectly to this
First initialize your instruments BTW: I am using an Agilent 34970A)
Then go to your Control state
Don't forget to shut everything down when you exit.
=== Engineer Ambiguously ===
Message 11 of 17
(1,467 Views)
Hi  ,
Thanks for your reply.
The vi doesn't stop now, but it gives me a timeout error. I have attached a cop[y of the modified vi. Please do let me know what corrections I must make again.
thanks for your time
Message 12 of 17
(1,463 Views)
@RTSLVU wrote:
Nobody cares about seeing the voltage the heaters are being run at. That does not tell you at a glance how hard the heating/cooling system is working.
You could always do something like this
Then you have throttle that goes from 0 to 100% and the voltage is still regulated in it's full range 0-120VAC.
Message 13 of 17
(1,442 Views)
That's just dumb and takes twice as much code.
Message 14 of 17
(1,433 Views)
Message 15 of 17
(1,404 Views)
@AeroSoul wrote:
Nice and compact, but I believe that is still more code than this: paCapture.PNG due to the two math functions and the formula node structure.
Message 16 of 17
(1,396 Views)
Actually if you made PID range 0 - 120 and then multiplied output by 0.833 it'd be the same amount of code 😄
Message 17 of 17
(1,380 Views)
