PID gain scheduler table
Hi everyone,
For my project, i am trying to build a lab View program to control temperature, pressure and vacuum in single zone and multiple zone furnaces and ovens especially for curing composite materials. I recently learned that PID auto-tuning is not accurate and might create unstable system. Thus, i am trying to implement PID gain schedule for the gain values. I was wondering what will be the best approach to fill gain values table for various temperature and pressure data. Thanks
(2,688 Views)
I suggest you to understand how PID tuning works.
Then you can use the method that suite your need.
In my case, I was using the Zeigler-Nichols.
It was more precise than the auto-tuning of LabVIEW.
I was able to control temperature at a precision of 0.001 degC on optical component.
The overshoot was very small and the response quite good to.
Benoit
(2,638 Views)
I've used both the advanced and the Smith Predictor auto tuning VIs successfully in past LabVIEW projects.
The auto turning VIs can sometimes provide a quick starting point that can be subsequently fine tuned for faster response, less overshoot, etc.
Playing with the simulated examples is a quick way to try it out.
Patrick Allen: FunctionalityUnlimited.ca
(2,625 Views)
Thank you. I am new to labVIEW and still learning.
(2,588 Views)
