PID instrumentation and application
Hi Milon,
@Chowdhury_Milon wrote:
As I said before, after getting the process value (PV) steady state (after 190 s in the picture), I want to stop this code and go to the supply step. How can I go to the supply step by stopping this nutrient solution preparation code?
What about changing that stop condition?
Maybe something like "stop when PV is in valid range for x seconds" - instead of "stop if PV is in valid range"?
Message 31 of 35
(1,320 Views)
Mr. GerdW
Yes, I agree with you but the PV setting time is not always the same. I can understand the condition but can't set the proper vi. I tried to use "In Range and Coerce" vi but it is not the proper one. Would you please give some suggestions or show some similar examples?
Message 32 of 35
(1,315 Views)
Hi milon,
you need to combine InRange with ElapsedTime to get your "pv is in range for a certain time"...
Message 33 of 35
(1,309 Views)
Hello Mr. GerdW,
Greetings. I am really sorry, I tried to combine the "In Range and Coerce" with "ElapsedTime" but can't succeed. if you have any idea, would you please share that with me?
Thanks in advance.
Message 34 of 35
(1,285 Views)
Hi Milon,
as usual:
What have you tried? Where did you fail?
As said before: the idea is to check for "is in range for a certain amount of time"…
Message 35 of 35
(1,279 Views)
