PID with controlled ramp Options
Thanks GerdW
these are Fig 1 & Fig 2 in PNG format.
the linearity is bad when i try to repeat experiment. 😞
Message 11 of 15
(1,708 Views)
Hi Ela,
As we don't know anything ybout your setup nor do we know the measurement values, so we cannot comment on those curves…
Did you change anything in your VI according to my recommendations?
Message 12 of 15
(1,691 Views)
Which information do you need about my setup ?
now I am working to change the code based on your comments and I will try to reapet the experiment again .
Message 13 of 15
(1,684 Views)
Dear GerdW
i did some changes in AI but the programme doesn't work i mean the temperature is 0 all the time .
please make right setting on DAQmx Read for me if you think something in rung or unnecessary please modify that
many thanks .
Message 14 of 15
(1,658 Views)
Hi Ela,
Did you also debug your VI?
Did you check the error outputs of all DAQmx functions?
- Why do you configure a sample rate of 1000Hz, when you read just one sample per DAQmxRead? With a timeout of 1000s?
- Why do you read this one sample as waveform when you want to work with a scalar value?
- Why do you need an ExpressVI for such a simple calculation?
- Why do you configure "buffer size" at DAQmxTiming in "continuous" mode? Did you read the help for that input?
Message 15 of 15
(1,622 Views)
