PID
I am trying to test a servo system, using a PID controller and the DAQ
PCI-4451 card. I used the PID Control Loop demo from the Solution Gallery
(LabVIEW 6i ), but I got the error:
" Error - 10403 occured at AI SingleScan.
Possible reasons:
NI-DAQ LV: The specified device does not support the requested action
(the driver recognizes the device, but the action is inappropriate for the
device) "
Is there a bad cooperation between the specific VI and the PCI-4451?
Are there any ideas for bypassing this problem ?
thanks in adcance,
M.
(2,866 Views)
M,
The NI DSA boards do not work with the AI Single Scan VI because it needs a scan rate for the delta-sigma and filters to work correctly.
Here a link to a knowledge base which gives a more detailed answer on this issue:
http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/862567530005f09c862566ac006adfcc?OpenDocument
The Knowledge Base also suggets a programming solution to error as well.
(2,866 Views)
