PID
Hey Guys,
I have written a code for a Fuzzy PID controller, which means I control the parameters of the PID based on fuzzy logic controller.
The problem is that when I connect the output of the fuzzy to the PID parameters, the output signal of the PID doesnt increase to find the goal. it stays constant.
If I write the parameters as constants it works, but when I connect it to the output of the fuzzy it doesnt!
Can anyone open my files and try to assist me?
Thank you
(4,423 Views)
Have you had a chance to try debugging your code? It's possible that the output of your fuzzy logic VI isn't what you expect it to be. Take a look at the link below for some ways you can do this:
https://www.ni.com/docs/en-US/bundle/labview/page/debugging-techniques.html
(4,357 Views)
Hey Scotia673,
Thanks for your attepmt to help, However, I don't think you understood my question,
I want to be able to continously change my PID gains.
It appears that the PID VI cannot handle PID gains which are continuously variable from iteration to iteration
I want the PID gains to change based on the output of every loop of the fuzzy Controller
(4,332 Views)
Accepted by topic author elsayeda
It looks like you posted this question in this other post:
http://forums.ni.com/t5/LabVIEW/continuously-changing-PID-gains/m-p/3144317
I also spoke with my colleagues, who you worked with over the phone, and he informed me that you were able to resolve the issue by changing the case structure in your PID VI which was being used to determine whether the gains had been changed to prevent the PID buffer from being disturbed. Glad to hear you got this resolved!
(4,298 Views)
(4,271 Views)
You're welcome! Enjoy your weekend.
(4,228 Views)
