PLC RS232 Communication without OPC
Hi my friend.
Thanks a lor for replying.
Where can I configure "tag updare rate" oí n Labview and un OPC?? I would like to probe that solution! Maybe this is the solution. Could you say wherw can I configure them?
Thanks again!
Message 11 of 16
(1,604 Views)
Hi friend! Did you see my last post? I can not find the update rate in Labview 😞
I thought as well with DataSocket pallete... You think I can achieve with that?
Thanks a lot!
Message 12 of 16
(1,581 Views)
I have worked hard this weekend in this and I think that the problem can be that i am loosing data in the comunication.
Because the PLC variable is from 0 to 500 (a timer) so 1,2,3,4,5....500.
But Labview sees maybe 1,3,5,6,9,12,20,21,30,31,32,33,38,42..... So for that reason I am doing osmething wrong...
Can anybody help me?
Message 13 of 16
(1,549 Views)
Hello to al.
First of all thanks a lot for reading this post and being able to help.
I am communicating a PLC with Labview via NI OPC Server.
I have a variable which is a timer in PLC. from 0 to 500 ms (1,2,3,4,5,6,7,8..........500)
I communicate good PLC and Labview but the problem is that I loose data on the way... because Labview does not see 1,2,3,4,5,6,7,8,9,10...500 because maybe it sees 1,3,7,8,9,12,15,20,25,28,30,35,42.....
So for that reason my app works wrong...
I have tried to use datasocket and put UpdateRate tag in 5 or 10 ms... but it works more or less in the same way.
Any idea for improving that or help??
Thanks a lot!!!!
Message 14 of 16
(1,558 Views)
Hi A.,
please don't create double posts for the very same question. Keep discussion in one place!
Message 15 of 16
(1,540 Views)
Ok, if you can help me...
Regards.
Message 16 of 16
(1,531 Views)
