PLC S5
How i find document for drive the s5 with lab view.
It's possible to link a serial Com direct to serial(DB 15) of the plc?
where is the cable?
Thank nicola
(3,037 Views)
Software Toolbox has an excellent AB PLC driver here:
http://www.softwaretoolbox.com/store/item_pages/itempage_59.asp - I've used it with LabVIEW, and it's great!
Your PLC manual should contain a wiring diagram for making a custom cable to plug in to your PC, although AB sells pre-made ones too - have a look at:
http://www.ab.com/plclogic/plc5.html and you should be able to find the cable you need...
Like my answer? Give it a rating!
cheers,
Christopher
Christopher G. Relf
Certified LabVIEW Developer
Christopher.Relf@mBox.com.au
Int'l Voicemail & Fax: +61 2 8080 8132
Aust Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed within it may not be purely my own, unless specifically referenc
ed I do not suggest they are necessarily associated with anyone else including, but not limited to, my employer(s).
2) This email has NOT been scanned for virii - attached file(s), if any, are provided as is. By copying, detaching and/or opening attached files, you agree to indemnify the sender of such responsibility.
3) Because e-mail can be altered electronically, the integrity of this communication cannot be guaranteed.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(3,037 Views)
No. You can't link directly PLC S5 with PC, because S5 is equipped with current loop DB15 serial interface.
You need RS232-current loop (TTY) converter.
As I know there is no drivers for S5 to Labview.
You can exchange data between Labview and S5 by means of any Industrial OPC Server.
NI offer drivers for S5 to NI OPC Server.
Romek.
(3,036 Views)
