PLEASE HELP!! My final year projects end in 1 weeks time. Is it possible to create a motion sensor labview program??
Hi New,
your circuit consists of a voltage regulator, your sensor and a microprocessor checking the sensor signal to drive a LED(?, right now it's just a diode and a resistor).
You have to replace the resistor R4 by your buzzer and LED, then half of your task is done. To send an email you need to use some DAQ device accessible by LabVIEW (USB6008?) and check the 8051 output state. Try to do that (I would start with a simple DAQmx "Digital input" example) and then we will continue with sending emails...
Message 11 of 20
(1,208 Views)
@NewToLabvieww wrote:
Yeah before i had my fyp i was having my attachment and all these is for 1 semester which last for only 6months.
WHAT IS FYP... Is FYP..
Spoiler
Five-Year Plan
For Your Pleasure
First Year Program
Fixed Your Post
Final Year Project
First Year Premium
First Year Players
Five Year Program
Foundation Year Program
Foundation Year Programme
For Your Perusal
Freight Yard Pub
Full Year Projection
Festival of Young Performers
Flexible Year Program
Kindly be generous while sharing your project related info... so that somebody can help you better and faster.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 12 of 20
(1,206 Views)
the following photo is the circuit that was done. And the green led does light up and the buzzer does sound when something is detected.
Btw, fyp means final year project
Message 13 of 20
(1,198 Views)
Hi New,
then again I have to ask: which kind of DAQ device do you have available? How will you get some measurement values into your LabVIEW program?
Message 14 of 20
(1,195 Views)
Flexible Young Petite! ;D
So, do this device have some cpu and/or serial interface, of do you have to measure the voltages of the card?
In the previous, it's a visa thingy, in the other you'll only need to measure the voltage over the buzzer/led with either a daq, or serial/ethernet communication to a DMM.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 15 of 20
(1,187 Views)
this have no interface with the cpu at all. And that is what i wanted to know how to do
Message 16 of 20
(1,184 Views)
Then you need to measure voltage via a DAQ-device or a DMM with communcation.
/Y
Qestit Systems
Message 17 of 20
(1,180 Views)
Hi New,
from the DAQmx point of view you want to measure either Voltage signals or DigitalInputs...
Message 19 of 20
(1,170 Views)
http://www.ni.com/gettingstarted/setuphardware/dataacquisition/digitaloutput.htm
is this the page that teaches one how to do it?
That's a good start, and Find Examples about DAQmx digital read.
/Y
Qestit Systems
Message 20 of 20
(1,166 Views)
