PNA Power Sweep, how to proceed?
I would like to perform a Power Sweep on an Agilent E8364C PNA.
I went through the Programming Reference and found commands for frequency and power sweep.
However there is little information on how the data is stored after a sweep.
How can I perform a double sweep:
Sweep frequency - for each frequency do a power sweep and measure Gain Compression.
I don't want to have to break this into a step-by-step process (1. Set Freq - 2. Set Power, Measure Gain - 4. Increment Power, Measure Gain... ...- Increment Frequency, repeat etc...)
Is there anyway I can avoid the step-by-step approach?
Thank you in advance,
(2,915 Views)
Ok,
I found out the E8346C does not have option 086 and so I can't do it in a simple way.
Does anybody know what the command is for a simple power measurement.
I just went through the entire Programming ref again but could not locate it.
Thanks!
Nicolas
(2,911 Views)
