PPL / LVLIBP Build Spec Naming Conventions?
Ooops... I don't see this in the properties dialog Smiley Surprised
I can try breaking this down.... need to spend some thoughts on how to do this properly...
Message 11 of 16
(1,426 Views)
Regarding the Generic_UI_Controller.lvlib: is this the only sublibrary?
If yes, it is possible that the build script automatically adds this entry. Only the PanelClasses.lvlib is marked as toplevel....
Norbert
Norbert
Expert: Geometry
Message 12 of 16
(1,424 Views)
No it's not, there are three further ones...
Oli
Message 13 of 16
(1,415 Views)
Hi Norbert,
I think I have found the root cause (at least what I consider it to be)
I have compared both "malfunctioning" build specs to the working one
<Property Name="Destination[0].destName" Type="Str">PanelClasses.lvlibp</Property>
<Property Name="Destination[0].path" Type="Path">../Build/PanelClasses.lvlibp</Property>
<Property Name="Destination[0].path" Type="Path">../Build/Debug/Debug_PanelClasses.lvlibp_donotuse</Property>
If you manually extend the malfunctioning one to
<Property Name="Destination[0].path" Type="Path">../Build/Debug/PanelClasses.lvlibp</Property>
Everything works fine! So the question is, why this manual modification is neccessary....
Message 14 of 16
(1,363 Views)
I assume that the _donotuse extension addition was added after finding that the build script doesn't succeed.
So the focus is on the filename itself: Debug_PanelClasses vs. PanelClasses.
So what i wonder is:
a) Is the failure connected to underscores?
b) Is it about the length of the filename and/or path?
Anyways, i am surprised that the configuration basically didn't create the 'working' filename/path at all. I can imagine that it's some kind of hickup regarding the first tab of the build script (location selection).
Norbert
Norbert
Expert: Geometry
Message 15 of 16
(1,359 Views)
Just tried to remove the underscores and re-save the project. LabVIEW will not add the PanelClasses.lvlibp token required.
Anyway we can call it hickup or bug. I can live with it as I have a workaround now.
Thanks for your help.
Oli
Message 16 of 16
(1,353 Views)
