PPL dependency absolute path
Hello
I have one common packed library located in C:\proj\common.lvlibp
Then I develop another project that uses this dll. When I move this project to another directory he expects that relative path to common.lvlibp is maintained. Can I somehow specify that this dependency is always located in C:\proj\common.lvlibp ?
What happens when commin.lvlibp is located on C drive and my project is on D drive? Then there will be no relative path?
(3,310 Views)
Edit,
i ve tested and seems t work correctly when
common library is located in D:\common.lvlibp
and another child is build to C:\dir\child.lvlibp later when I move child.lvlibp to another location it seems that is linked to common.lvlibp by absolute path.
Can this be done when project is build on the same drive?
(3,296 Views)
You may not be particularly excited by this idea, but you could load it dynamically by path if you needed to.
Obviously that's more work than static linking.
I haven't tried "special" locations (vi.lib, user.lib etc) but otherwise I think you'll have to maintain the relative path. If you use those, perhaps there's a loophole (not tried, no idea if true, just a possible guess).
An alternative workaround (this basically sucks, but if needs must and you can't rebuild to relink...) is to use a Directory Junction (not symbolic link) to create an alternative path to the directory that you need. I wouldn't in general recommend this except for specific, preplanned cases. But ymmv...
(3,268 Views)
Dynamic linking in that situation would complicate all too much.
Surprisingly it works when I reference ppl from another drive. child ppl can be moved without issues. I could create virtual drive and add directory junction between that and actual location 😄
(3,253 Views)
