PPLs improvements in LabVIEW 2025 Q3?
The LabVIEW roadmap states that "Build, load, and deployment time improvements for PPLs" has been implemented in LabVIEW 2025 Q3. But I don't find information about that in the release note.
Can we get more info about it?
(499 Views)
You should also check out the LabVIEW 2025Q3 bug fixes. I didn't see anything in there directly with PPLs, but that does not mean things were done that was not publicly documented to help PPLs. But I am with you. NI should answer what improvements were done.
(463 Views)
Do you have 2025Q3 and are wondering what the changes are, more specifically?
Or are you considering moving to it and want to know if the changes are significant enough to merit the move?
(411 Views)
Second option 😉
(387 Views)
