PROBLEM IN USING COM COMPONENT
I want to use com component in my application. I use the reference no, automation open and invoke method. I got list of the methods present in my com component. When i run the application error generated showing that null reference was passed. From reference no to automation open "0" was passed as shown in the probe. Can any body help me to resolve this problem
(2,723 Views)
Are you using the ActiveX container or the Automation Refnum control?  In both the cases, are you right-clicking and specifying the correct COM object?  You should not be getting a 0 for this refnum if everything is setup correctly.
Hope this helps,
-Khalid
(2,718 Views)
I am using automation reference no.
(2,704 Views)
What's the error output for Automation Open?
-Khalid
(2,688 Views)
