PROBLEM IN .exe CREATION
I am using labview 7.0,have got trouble in creating ".exe" file of my project.
without creating .exe there is no error in my project, so I there I can easily jump to next screen but  Once Exe is created it shows me some error.
 pls check attachment I which I have given snaps of error that my .exe is showing while run time.In my .exe main screen is working properly
as I wont but once I click on button to jump next screen then it shows VI break error.(i.e. missing subvi merge error in vi_ _ _ _xyz _ _ _ _.vi
pls tell me the reason behind this error
1] In my project i have used HTML report creation using REPORT GENERATION TOOLKIT, as we add supporting file for EXCEL REPORT i.e..   "_exclsub"
similarly is there any supporting file for HTML report which I have to add while creating .exe
2] DSC runtime engine file is not there in my PC.
(3,190 Views)
If you are using "paths" in your code, they need to be relative paths in order to maintain functionality when converted to a stand alone application. Using absolute paths could be the cause of your problem. Maybe!
(3,166 Views)
You cannot be serious!
Attaching ~9MB worh of useless images (one a picture of a broken run arrow!) is not efficient! Are these BMPs renamed to jpg?
(3,158 Views)
